antilock light on
Old Dec 14, 2004 | 07:36 AM
blakek's Avatar
blakek
antilock light on
help my anit lock brake light and parking brake light are on .no dragging brakes no loss of fluid ,parking brake not on .was fine the night before but this morning when i started up both lights came on and stayed on . extreme cold here in mid northern mi last night . also cold last night on drive home from work.. 1991 f150 ex-cab long box. 4.9 motor. rear anti lock only.
Old Dec 14, 2004 | 08:24 AM
sandrat's Avatar
sandrat
Check your fluid level sensor. It could be stuck on empty, or the circuitry could be shorted, open, or whatever. Also, check the abs sensor in the top of the differential. When it gets cold or wet, brake dust gets gummy or hard and can screw things up inside the drum, and particles can get on the surface of the sensor, which can play hell with things too.
Old Dec 14, 2004 | 09:47 AM
ham4ever's Avatar
ham4ever
I have a 88 f-150 4x4 and have the same problem with the anti-lock light staying on in cold weather. Sounds like sensor sticking. I noticed if I would hit the brakes and stop quick the anti-lock light would go out.
Old Dec 14, 2004 | 09:52 AM
RR4E's Avatar
RR4E
There are a few sensors in the anti-lock braking system. One on each wheel, one on top of the differential housing, and one on the transmission as well. I had problems with the one on the top of the diff housing on a work truck, and had it replaced several times due to cold/wet weather.
