Funny noise when running
Old Dec 14, 2004 | 03:33 AM
missouguy's Avatar
missouguy
Hey guys;
I was driving up the road at about 55 and noticed a slight knock (I guess) thought about the much talked about "cackle". When I came to a stop I got on it pretty good taking off. I then noticed the noise was gone. Could it be I am babying it too much? Input would be appreciated, new to diesel and trying to learn.
Thanks
Frank
Old Dec 14, 2004 | 02:43 PM
77hiboyboy's Avatar
77hiboyboy
Thats why ford/GM/Dodge?Toyota, ect puts radios in everything. Certain things just make certain noises.
Old Dec 14, 2004 | 03:06 PM
jesus_man's Avatar
jesus_man
Give us a little more info. Did you just leave your driveway or had you been driving for a while? Was it a constant knock-knock-knock or just one? Did it vary with speed? Have you had it in 4wd lately?
jman
Old Dec 14, 2004 | 11:13 PM
missouguy's Avatar
missouguy
It had been runing some, but not quite warmed up. No 4X4 yet. I was most noticeable on acceleration when cruising. The truck is really quiet once it is warmed up.
Frank
Old Dec 15, 2004 | 05:17 PM
444dieselrod's Avatar
444dieselrod
Sounds like your hearing the "fuel cackle" that so many of the newer (99.5 and up) 7.3 psd have a problem with, the number 8 injector is different and the fuel rails deadend in the heads so you get a "cackle" from trapped air.
do a search for it, I am sure you will find a ton of threads on it.
Diesel Rod
