Problem with lift kit
Old Jan 31, 2001 | 07:22 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Old Feb 25, 2001 | 05:26 PM
hattrick's Avatar
hattrick
I have a 2000 2wd Ranger, and am putting on 3" body lift. Everything is going great until I try to take off the cab mounts. The bushing and bolt just spins on the threaded washer, and we can't find a way to hold the flat, threaded washer to take off the bushing.
Anybody know how to get it off? Is there a special tool that I need to hold the threaded washer? Thanks for the help.
Old Mar 8, 2001 | 09:47 AM
mwittman's Avatar
mwittman
Yeah. I put a lift on my 2K 4WD ranger. We had to get a pipe wrench and pry against the washer while using a 1/2" drive socket and wratchet with the handle of a jack around the handle of the wratchet so we could slowly twist the bolt and get enough torque to break the bolt loose. A breaker bar might work too. All I have to say is..... have fun!!! Maybe if you're lucky, your last bolt will come off easy like mine did. If you have any more questions let me know.
Matt
2000 Ranger 4x4 Off Road
4.0L Borla cat-back dual exhuast
3" body lift, 285/75R16 Pathfinder ATR's
