Amp Subwoofer
Old Dec 13, 2004 | 08:50 PM
bigexpo's Avatar
bigexpo
Exclamation Amp Subwoofer
i have the mach audio system in my truck and i want to run the stock amp to a 4 ohm subwoofer (jl audio 12w3) and was wondering if this is safe since i hearrd the amp is 2 ohm's and the subwoofer is 4 ohms and if not how can i run aftermarket amp from the stock head unit
Old Dec 13, 2004 | 10:27 PM
sk8ingsmurf's Avatar
sk8ingsmurf
You definetly wouldnt want to do that because, for starters, that amp will be insanely underpowered and clip like hell, destroying your sub almost immediately, thats too good of a sub to waste (Im a huge JL fan). You can run a new amp of off your stock H.U., just buy whats called a line output converter (circuit city, best buy, local custom shop), dont buy amps with "hi-level inputs", they sound like crap and you will wish you hadnt, the LOC is the correct way to do things.
