Revving away for no apparent reason
Old Dec 13, 2004 | 07:30 PM
ukininkas's Avatar
ukininkas
My 1988 F-150, 5.0 l, 302 V-8, manual transmission pick-up occassionally revs up to 1500 or 2100 rpm seemingly on its own and then settles back down to the normal 750 on its own. I do have cruise control but never use it. The accelerator pedal is not being pressed. If I do press it it revs even higher. The throttle body seems clean and not hung up. Could it be something with the air bypass valve? Any other thoughts?
Old Dec 13, 2004 | 08:53 PM
wickymustang's Avatar
wickymustang
Either the IAC or the TPS, clean and check both.
Old Dec 15, 2004 | 03:47 PM
ukininkas's Avatar
ukininkas
Thanks. I didn't think of the TPS. I'll get to it shortly
