02' Ranger rollover won't start
My son rolled a 2002 ranger edge on it's drivers side. It was still running while on its side for about 2 minutes. he turned it off and after we rolled it back onto all 4 wheels it won't start. The starter will engage but the belts only move about 2 inches before it stops. We changed the starter after looking at it and seeing some worn brushes and it still won't start. Any ideas where we should look next?
Pull the plugs and try to crank it over.
Oil probably seeped into the cylinders.
Then on the passenger side fire wall you will find the inertia fuel cut out switch.
It is probably activated and I think you just have to push the plunger back down to start the fuel flowing again.
Good luck!
Good luck!
I agree and when you get that cleared I would check the fuel pump inertia switch as well. It is a small button that should be behind the kick panel on passenger side floorboard that kills the fuel pump in the event of an accident. Won't keep the motor from turning over but will stop it from firing due to lack of fuel.
Clarabelle
1983 - 2012 Ranger & B-Series
12-16-2015 02:06 PM
bryony
03-18-2007 09:29 AM
