Oil pan removal
Old Dec 13, 2004 | 03:49 PM
352 blue's Avatar
352 blue
Question Oil pan removal
How do you remove the oil pan with engine in truck.
Old Dec 13, 2004 | 03:58 PM
littlerayj's Avatar
littlerayj
What year? I can pull the pan on my 75 F350 by lifting the engine (360) up to just touch the firewall at the back and and lower the pan. Reach in and remove the oil pump bolts and allow the oil pump to fall into the pan. Going back together it is a little difficult to get the shaft and pump back up while in the pan but it can be done. Using a good sealer to hold the gasket in place helps too.
Old Dec 13, 2004 | 04:18 PM
gtex's Avatar
gtex
try the search feature in this forum. this has been discussed many times. You should find a full documentary on how to (and how not) to do this :-)
