Old Dec 13, 2004 | 01:47 PM
rmalottwtes30's Avatar
rmalottwtes30
300
Ok I have a 1976 ford 300 engine out of a truck and was wondering what all would be needed to put it in my 1980 ford 150, if it able to fit in it.
I am doing this because the 351m in it is all rigged up the motor mounts are homemade, the person before me didnt want to get a longer drive shaft so they just scooted the engine back, and i know its not safe to drive it. so any help would be nice.
Also what tools should I be looking at to do the trade. How high of a garage should I be in, because The garage its in right now is only 8'. Would it be alot nicer if I took off the doghouse?
Old Dec 13, 2004 | 04:28 PM
Mike G's Avatar
Mike G
Definitely take the hood off, makes anything much easier. Go to the local salvage yard and pull the engine mounts and stands from an early 80's truck that had a I6 or a Windsor motor. Then you can use those to drop in your I6. You will also need a new tranny or the bellhousing as the I6 will not directly bolt to the M based bell housing.
--Mike
