98 ranger
Old Feb 15, 2001 | 10:09 AM
ronno's Avatar
ronno
98 ranger
[font size="1" color="#FF0000"]LAST EDITED ON 15-Feb-01 AT 11:17 AM (EST)[/font][p]I have a 98 4wd ranger. while I am accelerating if I take my foot off of the gas I hear a clanging sound from the middle of the undercarage. Does any one know what this might be.
Old Feb 23, 2001 | 03:54 PM
goravens's Avatar
goravens
98 ranger
sounds obvious, but check your exhaust system for any loose hangers, etc. You may also want to fashion some sort of additional support for the exhaust system, as the factory setup is prone to vibration. Sometimes that sound comes from a loose tool box mounted in the bed and it transmits the sound through the frame and makes it a real nightmare to track down.
good luck...
Old Mar 27, 2001 | 11:09 PM
dproper's Avatar
dproper
98 ranger
I have a '98 4x2 ext cab with a similar noise. Mine seems to occur after completing a slow speed turn after decelleration and then getting back on the gas. There's a strong 'thud' associated with it. At first I attributed it to the torque converter or AT not downshifting, but then I read in the Haynes repair manual about the occasional lubrication of the sliding portion driveshaft yoke. I lubrated it and have not noticed the problem again. However, I try not to recreate the conditions b/c the 'thud' was unnerving. Hope this helps...
Old Mar 28, 2001 | 10:52 AM
ish's Avatar
ish
98 ranger
