Sponsored by: Real Truck
4X4 not locking?
Old Dec 12, 2004 | 11:16 PM
LANEGRA99's Avatar
LANEGRA99
Question 4X4 not locking?
my 4X4 is not locking the vacum lines are connected but nothing happens when i engage the four wheel, is this something covered under waranty?
i don't want a trip to the dealer so that they tell me i have to pay for a diagnose!
know what i mean?
thanks for the help
Old Dec 13, 2004 | 06:34 AM
kenneBF250V10's Avatar
kenneBF250V10
I had the same problem on one of the Super Dutys I had in the past, it was covered under the original 3yr/36,000 mile warranty. Problem turned out to be a bad seal (o-ring) on the hub assembly itself which resulted in a vacuum leak. Haven't had the problem on my '01, however, I did have to replace the entire hub assembly due to the retaining nut that holds the bearing in place splitting in half. What I am getting at here is, if your vehicle is not under warranty, get yourself a Haynes manual a new o-ring and do the job yourself, it's pretty easy.
Old Dec 13, 2004 | 08:59 AM
Big Orn's Avatar
Big Orn
Originally Posted by LANEGRA99
my 4X4 is not locking...
Do you mean transfer case and hubs or just one and not the other?
Old Dec 13, 2004 | 02:09 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Read this:
https://www.ford-trucks.com/forums/s...d.php?t=318370
Try locking the hubs manually, then using the ****
Old Dec 13, 2004 | 03:21 PM
LANEGRA99's Avatar
LANEGRA99
i can lock it manually but what is the point on spending $15,000 for a truck and then have to use the gadgets manually, not my idea of spontaneus adventurer.
well my main concern is since my truck "is" under warranty i want to milk it for all i can, know what i mean.
now is there anything i can do for maintenance after i fix it?
Old Dec 13, 2004 | 03:29 PM
Big Orn's Avatar
Big Orn
So it's the hubs that are not locking, right?
Are you sure that they're getting vacuum?
It could be that the hubs are bad or maybe a good cleaning will resolve the problem.
I guess you're going to let the warranty find and fix it. Since that's the case, if they do it right, the hubs shouldn't need maintenance except the standard cleaning after you travel through deep mud for extended periods.
Old Dec 13, 2004 | 03:36 PM
LANEGRA99's Avatar
LANEGRA99
Talking
i checked for vacuum so there is no problem there so i am just going to drive it to the dealer so they can figure it out.i really don't want to pay for anything right now its just not goood for my ego, 'cause if my friend find out that i had to spend money on it awredy i am going to be fried
just kiddin it'd still be nice though
Old Dec 13, 2004 | 07:17 PM
V10MARS's Avatar
V10MARS
There is a TSB about the huds not staying locked. Take it to the dealer. I has somthing to do with the shafts rubbing the back side of the locking hub.
Old Dec 16, 2004 | 10:48 PM
crz's Avatar
crz
Question
Originally Posted by krewat
Read this:
My hubs lock fine with the switch, however they will not turn manually. Are all models supposed to work manually also? 2000 model xlt scab 4x4 short whl bs.
Old Dec 17, 2004 | 10:18 AM
krewat's Avatar
krewat
I've heard about that - the ***** getting stuck - I think a silicone spray will work, but they are probably dirty as all heck.
Might be time to pull them apart - it's pretty easy looking - if they are so dirty that the **** is stuck, you'll probably need to replace the O-rings too...
But you could try some silicone spray first
