Sponsored by: Auxito
THANK YOU PCV tube replacement
Old Dec 12, 2004 | 10:33 PM
bobward737's Avatar
bobward737
Thumbs up THANK YOU PCV tube replacement
My sincere thanks for all those on this and the Expy Forum who posted info on replacing the tube/boot assembly on the PCV valve assembly.
I had the classic rough idle, low mileage, check engine light with a lean front bank code.
After reading a few threads here and on the Expy forum, was convinced to start cheapest: PCV tube boot assembly, DPFE, then EGR replacement.
The PCV valve tube assembly did it! The boot at the back of the manifold was swiss cheeese.
ALSO>>>>>>>ONE IMPORTANT POINT>>>>>>>>>>>>>>>>>
Leave the negative battery cable off for at least 10 minutes to give the computer time to clear. Oftentimes a minute or so won't do it.
Thanks to all of you who posted on this topic in the past.
Bob
