7.3 oil cooler replacement
Old Dec 12, 2004 | 04:25 PM
bobreid's Avatar
bobreid
I had to replace the head off the oil cooler because the bypass valve came apart. Do I need to replace o rings while I have this apart and is thier any prep for the o rings when I put it back together? I would welcome any tips or insight. Thanks
Old Dec 12, 2004 | 08:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You should replace the o-rings any time you have any system apart that uses o-rings, better safe than sorry. If you mix a little engine oil with some vaseline it makes an exceptional assembly lube for o-rings.
Old Dec 12, 2004 | 09:07 PM
bobreid's Avatar
bobreid
Thanks for the help!
Navistar444
47
Oct 9, 2019 03:35 PM
cummins0107
Nov 12, 2013 01:56 PM
90pioneer
18
Mar 26, 2013 12:58 PM
BobbyB
Oct 13, 2011 10:54 PM
grams72
Jan 24, 2011 09:47 PM
