1978 - 1996 Big Bronco
87 bronco stalling
Old Dec 12, 2004 | 02:19 PM
sacf250's Avatar
sacf250
87 bronco stalling
i looked at a 87 bronco 5.8l type m. the guy took really good care of it and has keept up on the services. the only problem that I could tell was that it would stal out even after it warmed up. it is an auto and the it is carberated. do you think it is the carb or is there some other problem that woudl be causing it . I would have bought it if it didnt stall. thanks for the help.
Old Dec 12, 2004 | 02:29 PM
greystreak92's Avatar
greystreak92
Could be a number of things. From the symptoms that you describe, sounds like a float and/or choke adjustment in the carb.
