rearend or trany
Old Dec 12, 2004 | 09:50 AM
sourpuss's Avatar
sourpuss
rearend or trany
i have a 89 diesel 4x4 5 spd 4:10 gears 200000miles and when i let out the clutch undr load i have this knoking sound as the wheels are moving it keeps going until i get up some speed then i dont know if its there or not but i dont feel or hear it, the transfer case was rebuilt not long ago so any idea on where to look first and what it would be
<!-- / message -->
Old Dec 12, 2004 | 02:56 PM
85e150's Avatar
85e150
What is the speed of the knocking?
Wheel speed could be axle bearing (a very short lived situation before it breaks or burns) or inside the diff. (also a short fused item)
Faster by 3 or 4: U joints.
I'd get this thing on a lift and have someone look at it while everything is turning. I'd suggest safety glasses, as something is about to let go.
Old Dec 12, 2004 | 03:03 PM
sourpuss's Avatar
sourpuss
it only does it {that i can tell}when im taking off from a stop iwould think a u joint but there new and always greesed
Old Dec 12, 2004 | 07:16 PM
85e150's Avatar
85e150
Since you just had work done, time to recheck anything that was unbolted.
I take it this isn't a knock that starts slow and builds in speed as you accelerate? If it knocks a few times as you get underway, look for loose mounts or crossmember. If it builds in speed, look again at driveshaft and axle.
This sounds like a minor problem now, anything you can do to speed the discovery will most likely save you a major problem or worse.
jddoelan
2004 - 2008 F150
Oct 11, 2005 11:04 PM
fatboy*61
All Things Towing
Oct 11, 2005 12:10 PM
F150Guy87
Mar 2, 2005 08:27 PM
yamahonda41
Computer Chips & Tuners
Dec 7, 2004 12:54 PM
spanky1071
Aug 11, 2004 01:54 PM
