4X4 Push Button
Old Dec 12, 2004 | 07:17 AM
tragene's Avatar
tragene
4X4 Push Button
I have seen many many posts on the internet about the 4X4 not engaging. I have a 94 Ranger and I have this problem also. One thing I have not seen is how to check the actual button. Is it safe to assume that if there is power prior to the button but nothing after the button,(while it is being pushed), that the problem is the button itself. Or is there anything else between the button and the ECM that will negate any reading after the button while the button is OK. If it matters, I have manual locking hubs
Old Dec 12, 2004 | 07:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and .
make sure you read the headings and Read First: notices in each forum.
Enjoy FTE
....MOVED.....
Old Dec 23, 2004 | 01:25 AM
AlfredB1979's Avatar
AlfredB1979
The shift motor seems to get crudded up and you get that same issue. Check your Haynes manual (you will want one now) and follow the steps to cleaning the motor...it will tell you how to shift manually as well!
Old Dec 23, 2004 | 08:39 PM
tragene's Avatar
tragene
Thanks AlfredB,
I have a Haynes and tried it all. I moved the motor and transfer case by hand. I replaced the motor with one I knew worked and replaced the button. Same result. My next step is to replace the ESC module. The interesting part is that even with the new button, I am still not getting any readings after the button though II do prior to the button. Normal electronics would suggest that nothing is getting past the button. Even if the motor or transfer case is bad, I should get juice after the button.
Thanks for your reply,
Richard
Old Dec 24, 2004 | 08:24 AM
Samsonitesamsonite's Avatar
Samsonitesamsonite
have you checked the simple htings... like the ground?
Old Dec 24, 2004 | 09:06 AM
sjwoody's Avatar
sjwoody
Hey all,
My Ranger is 2WD, but is the 4WD system the same as the Explorers..(91-94)????
If it is, there are all kinds of posts on the Explorer forum regarding this very problem and there's a good fix for it. Check this out:
http://www.marx7.org/~dsmith/t-fer_case_motor_fix.htm
