engine question ?
Old Dec 11, 2004 | 04:06 PM
mm68's Avatar
mm68
engine question ?
I can't find a wiring harness anywhere see wiring woes SO I had this idea I know its not street legel so lets say its for off road use Can a 94 302 fuel injected engine be made into a a carberated engine ? Would older heads bolt on if I can't use the the ones on there ?and would an older distibor work ? Would this require alot of work ?If so would an older engine bolt in and up to the trans?
Old Dec 11, 2004 | 06:28 PM
andym's Avatar
andym
You *can* make it into a carb engine. You'll need an intake and heads. It will require a LOT of work. The bellhousing patterns are the same, so the trans will bolt up. If your current trans is computer controlled, you'll run into problems there too.
All in all, it would be easier to swap in a new FI motor if you can't figure out the wiring harness things. I know, wiring on these things is complicated.
