Timing Question
Old Dec 11, 2004 | 11:28 AM
Doxy's Avatar
Doxy
Timing Question
I have a 1993 F-150 with a 302. I changed the engine and the junk yard said the new 302 was the same year. The problem is the firing order is not the same, My book says that the 302 I got from the junk yard is 1995 or newer. Do I set the time to the 1993 specs on the hood? If not does anyone know the new setting?
Old Dec 11, 2004 | 12:16 PM
mad_hacker's Avatar
mad_hacker
Your new firing order should be 1-3-7-2-6-5-4-8
Old Dec 11, 2004 | 02:26 PM
Doxy's Avatar
Doxy
That is the new firing order. Is the time still 10 degrees or has it changed?
Old Dec 11, 2004 | 02:38 PM
MustangGT221's Avatar
MustangGT221
still 10....
Old Dec 24, 2004 | 04:41 PM
countryboy4_1qt's Avatar
countryboy4_1qt
I swapped a 96 into a 93 sucker still idles rough but runs great other than sucking gas like mad I had to swap both intakes and all kind of junk because 96 are wired different than any other year but the motor only had 20,000 miles on it so if i can get the idle to smooth out and some better mileage it will be worth the sweat
