King pin blues
Old Dec 10, 2004 | 04:48 PM
Rodney F-100's Avatar
Rodney F-100
King pin blues
Having a real hard time replacing the kingpins on my 1960, the old ones do not want to leave, any suggestions, and if heat is involved what to heat the pin or the housing. Thanks in advance..
Old Dec 10, 2004 | 05:17 PM
TheMadFabber's Avatar
TheMadFabber
You heat the axle so it expands.
Sam.
Old Dec 10, 2004 | 06:18 PM
AXracer's Avatar
AXracer
Did you take out the lock pins?
Old Dec 10, 2004 | 06:43 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Yeah what he said take out the locking pin if you haven't yet.
If the 1960 is like the 1950 cut the washer off of the top so you can beat it out from the top down.
Heating it up helps
If you have a capable air compressor get an air hammer and beat it out with that. The air hammer worked the best for me.
Old Dec 10, 2004 | 08:11 PM
richard jobe's Avatar
richard jobe
king pins
also i live in channelview texxas couldnt get a machine shop to ream ,
one shop they broke their reamer ,wasnt going to buy another one, so
i end up doing it myself ,lasted real good for a while now rf is loose again
time to do it again, i will try harder to get a reamer nexxt time
life& limb houston freeways richard jobe
Old Dec 11, 2004 | 06:41 AM
Steve_B's Avatar
Steve_B
I pounded mine out with a big hammer, but one trick I read about on here a while ago is to jack up the front of your truck, place a bar between the floor and the bottom of the kingpin and SLOWLY let down the jack
Stephen
Old Dec 11, 2004 | 07:16 AM
Rodney F-100
Going to try the heat this morning, I have the truck up on stands and had a floor jack on the underside of the pin and raised it up about a 1/4" up off of the stand with no luck. Its been soaking with WD-40 all night hope things go well this morning, will keep you all posted...
Old Dec 11, 2004 | 09:05 AM
JDMick's Avatar
JDMick
Get everything cherry red and pound with a maul, not a hammer, and it'll come out. If you don't have an acetylene or propane with oxygen torch you should seriously consider getting one.
Old Dec 11, 2004 | 09:28 AM
AXracer's Avatar
AXracer
A MAP gas torch will work for heating if you are patient enough and keep an extra cylinder or two handy.
PS: WD40 is actually a poor penetrating oil, it's just 10 weight motor oil in a spray can. Use Liquid Wrench instead the difference is night and day.
