Sponsored by: Real Truck
lockout problems
Old Dec 10, 2004 | 12:38 PM
d60429's Avatar
d60429
lockout problems
i was just wondering if anyone has had problems with there lockouts on there 99up superdutys. because mine will not work at all automaticaly and it is everything i can do to turn them by hand it feels like something in the vacume is messed up
Old Dec 10, 2004 | 01:41 PM
etcetera's Avatar
etcetera
It's pretty common for them not to work. If they are hard to turn, they probably need to be taken apart cleaned and lubed.
Eric
Old Dec 10, 2004 | 01:56 PM
sdoomaha's Avatar
sdoomaha
One of mine is making considerable noise. I ahve removed the retainer ring, but am still having problems removing the lock out. Is there a trick? Was also warned that it can come out in several pieces and be hard to get back in.
Pointers?
Old Dec 10, 2004 | 02:00 PM
DCSpecial's Avatar
DCSpecial
Once you remove the ring it should just slide out......a couple of slight hits with a dead blow may help. Mine didn't really want to come out too easy so I tapped them a couple times and they slid right out.
