Bronco II Ford Bronco II
RABS question
Old Dec 10, 2004 | 09:25 AM
hotrodmerc's Avatar
hotrodmerc
RABS question
My 88 Bronco II RABS light is on when it's coldor wet outside. Otherwise it stays off while driving on occasion it will blink whil driving. I have tried to pull the codes but get nothing. I looked in the tech section but could not find the codes for the RABS. I'm going to bleed the rear brakes but they are working ok. I just need the codes I am going to try to get them again.
Old Dec 10, 2004 | 10:18 AM
mrshorty's Avatar
mrshorty
The RABS system dopesn't have a memory, so you have to pull codes while the light is on.
Old Dec 10, 2004 | 10:21 AM
hotrodmerc's Avatar
hotrodmerc
Thank's I'll try that.
Old Dec 10, 2004 | 03:36 PM
Ken00's Avatar
Ken00
Then post the codes and I'll hook you up with the pinpoint test.
Old Dec 13, 2004 | 04:42 PM
hotrodmerc's Avatar
hotrodmerc
I'll try to get this done this week. It's hard when you are working around 60-70 hrs a week.
Old Dec 16, 2004 | 03:02 PM
hotrodmerc's Avatar
hotrodmerc
Tried to ground the orange/black wire. I got no codes. Light is still on.
Old Dec 16, 2004 | 06:06 PM
Ken00's Avatar
Ken00
Are you sure you grounded to a good, clean spot. Is the connector at the master cylinder tight, clean and good? How's the RABS fuse.
