hello,
I have a 98 2.5 XLT Ranger and lately I have been getting a little hesitation when trying to accelerate. I am getting close to 30k, is there anything I should be weary of.. anything that I should check for sure besides the normal tune up stuff..i.e. spark plugs, oil, oil filter..?
you failed to mention your transmission type-if you have an automatic, it's past time to change the entire fluid and filter. otherwise, normal stuff like you listed you should check-also don't forget to check/replace your filters too!
[font size="1" color="#FF0000"]LAST EDITED ON 13-Jun-01 AT 09:19 AM (EST)[/font][p]I would replace the spark plugs and if that does not help I would remove the MAF sensor and the IAC sensor and clean with eletronic parts cleaner. Most likely you have a spark plug that is hosed up.
