Conversion Questions?
Old Jun 25, 2001 | 11:48 PM
ford4x4offrd's Avatar
ford4x4offrd
I want to do the swap from 2.3L to either a 302 or 351 Windsor. in the truck right now i have:
Transmission:
Model #: FM145
TNM Assembly #: E67A7003FB
Build Code #: 064551
Transfer Case:
On the side: B05731350-17
On the bottom: 292333B67A-G
I need to know what tranny, and transfer case will bolt up to the motors above. also what gear ratio will be right in the rear end, the rear end # is 7022. the rest of the tag is not there. i know i can get the conversion kit, but for the rest of the drivetrain i dont know what will bolt up. thanks for any info.
|x| Jacksland |x|
Old Jun 26, 2001 | 05:04 AM
dynamic's Avatar
dynamic
pick up a copy of the conversion manual , from advanced adapters, they cover all the conversions, they sell adapters for the transfercase and let you know what you have to modify to make the swap work,
you can get this manual from your local speed shop, or 4X4 shop.
good luck
75 F-250 4X4 360 with 81 body
86 Ranger 302 with C-4 trans and 91 nose
Old Jun 26, 2001 | 11:07 AM
ford4x4offrd
Ill check the conversion kit out. thanks for the info
|x| Jacksland |x|
Old Jun 26, 2001 | 05:37 PM
fuquan's Avatar
fuquan
