Sponsored by: Real Truck
Shackles or Add a Leaf?
Old Dec 9, 2004 | 12:06 PM
emag's Avatar
emag
I've got a fab-tech 3.5 leaveling kit. I need an additional 1 to 2" more lift up front. I want to do this without replacing the original lift.what is the better route, using shackles or an add a leaf? 04 CC 6.0l 4x4 Lb. thanks in advance.
Old Dec 9, 2004 | 04:25 PM
DCSpecial's Avatar
DCSpecial
A 2" mini spring pack would be a better route IMO....you'd also need a drop pitman arm, drop trac bar bracket, sway bar links. In the rear I'd go with a replacement spring pack or you could get a 5-6" single block.
