trans problems
Old Dec 9, 2004 | 07:15 AM
countrysF250's Avatar
countrysF250
trans problems
well this mornin when i got off work i started off down the road and the trans started downshifting by itself, i pulled over and checked everthing out fluid and all was ok. now it seems fine when taking off and highway driving but it don't want to change gears unless u step off the gas other than that it does not seem to be slipping and i have all the gears including overdrive any help appreciated.
Old Dec 9, 2004 | 07:36 AM
Casey's Avatar
Casey
Sounds like something's wrong.
Without any information about what year and what model and what engine/transmission, there isn't much else I can say about it.
Old Dec 9, 2004 | 07:40 AM
Fordafied's Avatar
Fordafied
My truck did the same thing. It would not shift out of 1st unless you let off the pedal. All the rest shifted fine. The fix " A new transmission". I took it to the dealer for testing. The dealer can hook up a Transmission diagnostic machine and tell what’s wrong. The test along was $75. New "rebuilt" transmission $2675.00 w/3yr/36000 warranty.
Old Dec 9, 2004 | 07:44 AM
Fordafied's Avatar
Fordafied
If you hold your mouse over the signature of countrys250, you will get all this info. Just a little help for the future.
Old Dec 9, 2004 | 12:00 PM
78fordman's Avatar
78fordman
Well, it sounds like a bad TPS sensor. Stuck on a high perdcentage, try testing the TPS sensor.
Old Dec 10, 2004 | 02:41 PM
countrysF250
well the dealer called me today said the one way clutch for second gear had went out they want around $2,000 to fix it or i can take it to a trans shop and have them rebuild it for around $1,500 what do ya'll think i should do and why do u think it went out so soon the truck aint got but 35,000 on the odometer.
Old Dec 10, 2004 | 02:42 PM
countrysF250
and by the way its a 01 F250 psd auto
