Sponsored by: Real Truck
60K=Check Engine Light?
Old Dec 8, 2004 | 11:47 PM
KeninCali's Avatar
KeninCali
Question 60K=Check Engine Light?
I have an '02 F250 CC,4X4, V10. When I hit 61211 miles, the check engine light came on. I was talking to a mechanic friend (not a Ford mechanic), said the Fords engine light will come on at around 60K for scheduled service. Said to take it in, have them scan it just in case. He said 9.9 out of 10 times there's no issue with the truck, but it'll cost around $30 bucks to have them clear the light.
The truck runs great, no change in performance...
Any truth to his statement?
Old Dec 9, 2004 | 06:01 AM
slc10844's Avatar
slc10844
Normally if the light is on a "hard" code has been set and has an emission related problem.
Old Dec 9, 2004 | 06:55 AM
Brad99SD's Avatar
Brad99SD
Have autozone check the code for you, they do it for free. Mine SES went on at about 87,000, it ended up reading an P0401 code (low flow egr). I checked the egr valve with a vacume pump and it was fine. There is a sensor called a DPFE(Differencial Pressure something or other), it can go bad giving the computer a false reading for the egr system. It was only $40 at the local dealer, installed it myself and it's been fine for the last 20,000mi. They were supposedly notorious for going out on the 99 modle years(that's what I have), and the new one did look a bit different physically. I guess what I'm saying is get the code read before you take it in to the stealership. Good luck
Old Dec 9, 2004 | 06:57 AM
Brad99SD's Avatar
Brad99SD
Oh yah,
I may be wrong but I don't think that ford hard codes there SES light to come on for scheduled service. Anyone else know?
Old Dec 9, 2004 | 07:24 AM
Big Orn's Avatar
Big Orn
Originally Posted by Brad99SD
Oh yah,
No, they don't.
This guy is blowing smoke.
Get the codes read from an auto parts store for free. Forget all that automatic check engine junk.
Some people....
Old Dec 9, 2004 | 11:16 AM
KeninCali's Avatar
KeninCali
Thanks guys, that's why I always stop by this site if I have a question...
"Stealership"...HAH!!! I've never heard that...That must be the synonym in the dictionary.
I'll have it checked at AutoZone.
