Brake lights not coming on
What vehicle is it. It depends on the vehicle - '73 and newer uses a electric switch on the brake pedal arm, the older ones have a switch in the brake lines that's activated by brake fluid pressure.
Both types of switches should have two wires with one being hot always and both hot with pedal pushed down. Get a test light or volt meter and check for power.
Marty
Marty
