ford 9 " brake conversion.
Old Dec 8, 2004 | 05:55 PM
sara_james's Avatar
sara_james
I am trying to decide which kind of disc brakes and the best brakets to use. I could really use help with drawings or technical info on the swap from drum to disc. I am using a ford 9 " that is 57 inches backing plate to backing plate. Is this too narrow?
Old Dec 8, 2004 | 06:26 PM
bememe's Avatar
bememe
Smile 9" brakes
Hey Sara_James, I have the Explorer disc brake kit from Currie on my 9". You can see a picture in my gallery. I can't vouch for wether they are better or worse than anything else. I also got an emergency brake cable kit from Currie which are actually Lokar. I was able to use the front half of the stock e-brake system and connect the cables to it. I would have to do some measuring to give you my opinion on the 57".
Old Dec 8, 2004 | 08:19 PM
mtflat's Avatar
mtflat
If this is for your '54 then the 57" measurement is right on the money. Same as your stock rearend.
FLJ
Sep 8, 2015 12:42 AM
hasteranger
17
Sep 30, 2011 09:56 AM
captbo
Jan 12, 2011 07:32 AM
FLJ
Jun 18, 2010 03:09 AM
A&Asuperdog
Sep 28, 2009 05:22 PM
