"NEW" turn signal switch......
Ya, great.....I hope yours was better than mine....
Man, talking about
. How's that saying go..."nothing like a man with faulty car parts..." (or something like that..LOL!)The story so far.....
I order this "new" switch for my '67 F100. Mine has been ailing for the two years I've owned this truck. I finally broke down and got the switch($70) and went to install it last night. I pulled the steering wheel, disconnected the pins from plugs under the dash and pulled old switch out. I then fished the new wires down the column(that's a trick without pulling the hub off top of column) and then installed screws to retain switch. Great, now just put wheel on and try'r out
. Well complete threads anyway
. I then had to put it all back together with old switch so I could drive it
.I brought "new" switch to work with me so that I could use a 1/4"-28 tap to properly install THREADS in "new" switch
. Can you FEEL the love
. Luckily I work at a machine shop, so taps are easy to come by.I'm usually pretty easy to please.........but come on!!!
Now, I could call the place, complain, send it back, wait for another one, etc. Why, I want it fixed now and I have the capabilities to make it work.
Just needed to vent..............
Word to the wise....check all new parts for completeness BEFORE tearing anything apart. Nothing worse than having to do it twice because someone else screwed up. It's bad enough when I screw it up
Well, anyhow, glad you solved your problem.
It just really caught me off guard and really turned my crank when I went thru the work to fish the wires to only find I had to do it AGAIN once I rectified the problem.
I did buy one of the "replacement" rear e-brake cables...and it was a joke. Ended up finding a real replacement from local Napa. LMC had this "adjustable" version that had hose clamps
holding it. It would collapse everytime you pressed the brake pedal. Junk. That has been the only two things I have had problems with. All in all, not bad. I guess I got that one in a thousand that was not up to specs.
Wonder why yours was $70?
Keith
Freight, you always have all the fun.
