1978 - 1996 Big Bronco
4x4 Engagement
Old Dec 8, 2004 | 01:50 PM
jrich14's Avatar
jrich14
4x4 Engagement
I have a 1996 Eddie Bauer Bronco. It has a push button 4x4 engagment and automatic hubs. The other day I got stuck, when I pressed the 4x4 button I heard a clicking-grinding sound. That was followed by a huge clank when it caught into 4x4. Does anyone know what the problem is and how to fix it.
Thanks.
Old Dec 8, 2004 | 02:32 PM
muckypaws's Avatar
muckypaws
were the wheels spinning when they engaged? if so that would cause a clank as the clutch in the xfer box tried to engage with a rotating shaft.
Any help?
(My original answer was going to be "the problem is you got stuck" but I didn't think that would help much! )
Old Dec 11, 2004 | 11:45 AM
Jtanner76's Avatar
Jtanner76
4x4 low probs
i cant engage into 4x4 low gear. 93 electronic shift 4x4
Old Dec 11, 2004 | 12:32 PM
muckypaws's Avatar
muckypaws
the other thing to bare in mind as its a mistake I made until I got an owners manual imported from Florida is that 4L can only be engaged when the transmission is in N. 4H can be in any state.
Forgive me if I am preaching to the converted.
Simon
Old Dec 11, 2004 | 03:43 PM
Beast12's Avatar
Beast12
Yes, make sure you are in Neutral. It will make a HUGE difference! And NEVER shift when you are spinning your tires.
-Matt
Old Dec 11, 2004 | 05:52 PM
Outlawwv's Avatar
Outlawwv
do a search on this and you will find lots of info it is a common problem -- mine does it too
