Instr. panel options ?
Old Dec 8, 2004 | 10:00 AM
GPA's Avatar
GPA
Hey guys,
I'm fixing up the interior of our project 64 cc, I have looked and looked for a dash insert for this truck that I can put an electric speedo set-up in, and I have had no luck.I would like to put all new gauges in at the same time,so if anyone knows of such a insert that would house all new gauges ,please let me know.
Thanks, GPA
Old Dec 8, 2004 | 01:04 PM
CustomCab4x4's Avatar
CustomCab4x4
Smile
If you have the inclination, it's pretty easy to make your own inserts and then put in whatever you want.
Good luck, Phil
Look here and see what I mean:
I painted it with wrinkle paint after deciding I didn't want polished alum on the dash. But that would be easy to do too.
https://www.ford-trucks.com/user_gal...d=1941&width=2
Old Dec 9, 2004 | 06:22 AM
jowilker's Avatar
jowilker
Phil, Interesting how you can have the tach ideling at 1200 rpms while not in the truck
John
Old Dec 9, 2004 | 06:27 AM
CustomCab4x4
Smile Can't wait to get started?
Yeah I know. That truck has been apart and setting SO long it's anxious to get started!!
Actually, I think it's because it's an electric tach and the needle wanders a bit when it's layed over like that. (it seems to work ok though)
Later, Phil
Old Dec 9, 2004 | 08:47 AM
truckfarmer's Avatar
truckfarmer
check out the billet inserts here....http://www.jbmicrofinish.com/ They can custom make anything you want for these trucks.
Old Dec 9, 2004 | 01:14 PM
CustomCab4x4
Talking
Come to think of it my Galaxie's tach does the same thing. See:
http://groups.msn.com/FordGalaxieCol...to&PhotoID=154
Old Dec 10, 2004 | 07:45 AM
jowilker's Avatar
jowilker
I suppose if ya have one of them ol Holman Moody engines driving it, it is trembling, afraid of having it's head rung off.
John
Old Dec 10, 2004 | 08:55 AM
MyDads64's Avatar
MyDads64
Tach in 64 Custom Cab
This is how I installed a tach in my 64 Custom Cab.
http://groups.msn.com/slick60sfordfseries61to66/mydads64.msnw?action=ShowPhoto&PhotoID=536
The URL doesn't seem to work from here, so copy it and paste it to your IE address bar and it will take you there.
Old Dec 10, 2004 | 12:04 PM
Sam_Fear's Avatar
Sam_Fear
MyDads64,
I saw that before - a great idea for a small tach! And I noticed you've got the amp and oil gauges too. Nice dash:
https://www.ford-trucks.com/user_gal...=29354&width=0
Old Dec 10, 2004 | 07:28 PM
MyDads64's Avatar
MyDads64
Sam_Fear, thanks for the compliment. The gauges work fine. I had to install a rheostat to the lights in the gauges to match them to the rest of the dash lights. It took me a while to find the tach that fits there on the steering column bracket. Unfortunately, it only works on 61-64, as they changed the column bracket in 65.
How did you get the URL to work? I copied it from the address bar while looking at the photo, but it would not work. The URL you posted does work. What is the trick?
thanks,
norwood
Old Dec 11, 2004 | 01:57 AM
Sam_Fear's Avatar
Sam_Fear
The link I used is to an FTE address (your FTE gallery). Your link is off site. Some off-site links simply don't work.
BTW, that is one sweet truck! I don't think I could even own a truck like that - I know myself, and I just wouldn't give it the attention it deserves.
Old Dec 11, 2004 | 12:47 PM
mikeescott's Avatar
mikeescott
My dash project.
Here is what I did with my dash. I cut the back out and cut a piece of diamond plate aluminum to fit ove it. I then used adhesive Bondo to glue it in there and fill in the gaps. I got a set of hot rod guages from VDO and put them in there. Not a great job, but the first time I fabricated anything. Since this pic, I have added high beam, alternator, and turn signal indicators. Recently I have also added front lit blue led lights to light the panel up blue, like my truck.
Old Dec 13, 2004 | 05:52 PM
CustomCab4x4
Smile
Ha! Yeah John, I WISH I had a H&M firebreather in there. I imagine it's just gone "limp" from laying around so much.
Later, Phil
John
Old Dec 15, 2004 | 12:56 PM
pops-toys's Avatar
pops-toys
In an earlier post, JB Micro Finish was mentioned and their web address was provided. I am now ready to by an insert but the web site seems to have gone away. Does anyone know if they are out of business or have a new address?
Thanks in advance
Pops
Old Dec 15, 2004 | 02:32 PM
james northen's Avatar
james northen
To customcab4x4 re dash insert
Phil, I just read your post on 12-08 and looked at the picture of your instrument panel. I'am curious about the red object at the bottom of the speedometer. Is that a light sourse for illuminating the speedometer. If it is could you tell me what you used to do that with. I'am having trouble seeing mine at night and have been trying to figure something out to be able to see it better. Thanks James Northen
