1978 - 1996 Big Bronco
Replacing EGR Valve
Old Dec 8, 2004 | 02:08 AM
davdogg39's Avatar
davdogg39
Replacing EGR Valve
Yo, i have a 92 Ford bronco V8 351. need to replace EGR Valve . Would it be best to take it to a shop or can i do it myself? also any precautions I have to take? Thanks
Old Dec 8, 2004 | 02:28 AM
SproutW's Avatar
SproutW
Nothing to it. Just pull off the vacum line, unsecrew the large nut connecting the pipe to the EGR and the two bolts holding the EGR to the intake. Once the EGR is off you just have to remove the plastic EGR position sensor (three screws) on the top of the EGR and put it on your new one. I recommend you replace the position sensor with the EGR though. I would also use some penetrating fluid on the pipe nut to make removal alot easier. Have fun.
Old Dec 8, 2004 | 02:40 AM
davdogg39's Avatar
davdogg39
Thanks SproutW, sounds easy enough .
Old Dec 8, 2004 | 04:39 AM
SproutW's Avatar
SproutW
No prob. this is a great forum.
Old Dec 8, 2004 | 09:39 AM
Kemicalburns's Avatar
Kemicalburns
by a haynes manual and then most of your questions will be answered with step by step instruction , with pictures even lol
