Axle Code Help
Old Dec 7, 2004 | 03:48 PM
71 Sport Custom's Avatar
71 Sport Custom
Axle Code Help
I've searched many threads for hours to decifer my axle code with no luck. Was hoping to get some help. The first line is V126A. Second line is 3.55 10 2 5E17. Thank's for any help you may be able to give.
Old Dec 7, 2004 | 09:26 PM
SoCalDesertRider's Avatar
SoCalDesertRider
That appears to be a Ford Sterling 10.25" rear axle from a mid-eighties to '97 F250/350 with 3.55 ratio and open differential. Should have 12 bolts around the rear cover and fill plug in the driver's side of the housing ahead of the axle tube, instead of in the rear cover. Someone else here can probably tell you the date of manufacture from the other numbers.
