Leaking Steering Box
Old Dec 6, 2004 | 05:49 PM
OldFred's Avatar
OldFred
Hello all
Have a leaking steering box and was wondering if, before I get in there, there is a particular piece or area of the box that is usually the culprit when it comes to leaks so I know where to start looking? Maybe a seal or something that is pretty common to start leaking? Ok, well thanks for any info on that and on how I would go about replacing whichever part is the guilty one.
Thanks
Old Dec 6, 2004 | 06:49 PM
F150'89's Avatar
F150'89
Question
The pitman arm shaft seal is the one that leaks the most but also check the pressure and return hoses because they will also leak.
Old Dec 7, 2004 | 09:29 AM
OldFred's Avatar
OldFred
Thank you. Ill start with the pitman arm seal. I appreciate your response.
