88 ford ranger
Old Dec 6, 2004 | 03:41 PM
Enterprizer's Avatar
Enterprizer
88 ford ranger
Got a 88 Ford Ranger with a 2.3. Every now and the it act up by idle going up and down. Shut and restart it and its fine for a while again. Changed plugs,wires, fillters and even TPS but still does it. Any Ideas
Thanks
Old Dec 6, 2004 | 08:23 PM
Ken00's Avatar
Ken00
Are you getting any codes, have you checked for damaged vacuum lines?
Old Dec 7, 2004 | 05:26 PM
Enterprizer
Haven't got no codes and far as I can no no vacum leaks. Did find out that part of the problem for it staliling was the switch on the passanger side floor for the gas switch was faulty so I bypassed it and now all it does is now and then is idle irracticaly.
Old Dec 7, 2004 | 08:51 PM
Ken00's Avatar
Ken00
I would take a closer look for vacuum leaks and cleaning the IAC.
DON'T bypass the inertia switch, if your in an accident, have a broken fuel line and trapped, it's not a good thing, the pump will empty the tank all around you.
Old Dec 7, 2004 | 09:05 PM
Enterprizer
Smile
Ordered a new switch already, just bypassede it till it came in. Will keep looking for vacum problems. Thanks for the info
