94 Expl. chip upgrade?
Old Dec 6, 2004 | 04:23 AM
inthedirtagain's Avatar
inthedirtagain
Anyone done an aftermarket chip upgrade? I am considering doing this to my 94 manual, and was wondering if it's even worth it. I've already done the intake and exhaust. What's your input?
Andy
Old Dec 6, 2004 | 06:22 AM
bulldog3531's Avatar
bulldog3531
what type of intake and exhaust did you put on your truck and how well does it perform?
Old Dec 6, 2004 | 06:45 AM
inthedirtagain
I removed the factory intake/filter box, and installed a 3in cone-type hi flow filter. Similar to K&N, but a hell of a lot cheaper. On the exhaust side, I removed the original muffler, and welded up a free-flow turbo, with larger outlet diameter. With these mods, I picked up a little bit more acceleration, with better tonality (it actually sounds like a man's 4x4)
Old Dec 8, 2004 | 07:38 PM
Bashman's Avatar
Bashman
I have a '93 that I added a K&N type filter, magnaflow cat-back exhaust, 66mm throttle body and 70mm MAS and noticed quite a bit of difference. I would definately recommend the larger TB and MAS. I then added an ***** chip and noticed another slight increase. IMHO I thought it was worth the $$$.
Old Jan 16, 2007 | 12:27 AM
92 ExpSport's Avatar
92 ExpSport
hey inthedirtagain...
Where did you find the 3in cone- type filter? I've looked and can't find one for under 200 bucks!
Old Jan 16, 2007 | 12:21 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
I'm a fan of the simplicity of the Hypertech Power Programmer http://motorhaven.autoanything.com/performance-chips/61A1785A0A0.aspx?kc=MOTORH
Old Jan 17, 2007 | 09:33 PM
79 Trailer Special's Avatar
79 Trailer Special
jet performance makes a module (chip) also
Old Jan 17, 2007 | 11:54 PM
MisterCMK's Avatar
MisterCMK
Not for the Explorer and the 1994 is OBD1 which needs to be chipped
