Stuck in 4WD?
Old Dec 5, 2004 | 09:14 PM
RodbusterGS's Avatar
RodbusterGS
Stuck in 4WD?
Just got a quick quesiton for anyone who might be able to help.
I've got an 01 PSD w/ 4WD. This morning I was going out to the store at about 8 am, it was about 10 degrees out. I started the truck up and quickly found I was stuck in a patch of icy mud in my parking lot, so I threw it in 4 wheel (electronic shift). After I extricated myself from the hole, I shut the 4wd switch back to 2wheel, but the 4x4 indicator light on the dash stayed lit. I tried a couple of tight turns, and Im sure my front wheels stayed engaged. Just wondering if anyone my know why this happens? I was a little leery regarding the ESOF, I would much rather have a lever that engages/disengages...there is something about shifting into 4wheel with a **** that looks like it adjusts the radio... . Anyways, I eventually got 4wheel to disengage, but still, its annoying problem, and I've really got no idea why its goin on. Any help is appreciated....Thanks!
Greg
Old Dec 7, 2004 | 08:09 AM
kilroy99's Avatar
kilroy99
According to the owners manual for my 99 psd, if your wheels are spinning at all the computer will not let it shift in order to prevent damage to the system. Maybe thats it.
Old Dec 7, 2004 | 06:39 PM
clux's Avatar
clux
You have essentially 2 different systems to engage 4-wd, a vacuum system (for the hubs) and a separate electric motor for the transfer case. Because they would both have to fail for your truck to stay in 4-wd I would suspect a problem wiht your dash switch itself rather than the downstream components.
