strait six
Old Dec 5, 2004 | 07:45 PM
sacf250's Avatar
sacf250
strait six
i am thinking about picking up a f150 1984 and it has a strait six. can any one tell me what size the six would be. also if there is any draw backs and what kind of gas miliage would I get. thanks
Old Dec 5, 2004 | 08:38 PM
5_labsownus's Avatar
5_labsownus
300 cid I6 or 4.9 L I6. It's the same.
Old Dec 6, 2004 | 12:22 AM
andym's Avatar
andym
Gas mileage will depend on what tranny you have, what gears are in it, and how you drive it. Your mileage will be between 12 and 19, probably.
There are no drawbacks with the straight six. You get on of the longest lasting, most durable motors ever made, you get incredible low-end torque, and bragging rights for being able to out-pull a lot of small block V8s.
Old Dec 6, 2004 | 09:11 AM
wickymustang's Avatar
wickymustang
One and only minor draw back, this is not a high reving engine. Don't expect to get it up around 5k and keep it there. It will tow just about anything you can hook to, but not at land speed records. It will always get you there, just closer to 55 not 80mph
Old Dec 6, 2004 | 03:52 PM
85e150's Avatar
85e150
Watch for TFI ignition (sudden failures) and loose exhaust manifolds.
Easy to work on, and not much needs to be done.
5 speed non-granny tranny?
That's a Mazda box and you should go read the tranny threads about fluids and replacing the failure prone plugs on top of the box.
Many miles of happy motoring!
