Amp draw from the block heater.
Old Dec 5, 2004 | 01:15 AM
ac1108's Avatar
ac1108
I am curious as to what the amp draw is for my block heater so I can purchase the correct extension cord. It's a 99 if that helps any. I would hate to call the insurance man and tell him that my house and truck were burned up because I used a smaller gauge wire than needed. If I knew the wattage I would be able to answer this question on my own but I'm not sure what they came out with. I'm thinking I will use 12 gauge wire to be on the safe side but with the price of fuel where it is why spend it if you don't have to?
Old Dec 5, 2004 | 04:27 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I researched it for you and learned that the Powerstroke block heater pulls 1500 watts. Using Ohm's law :
power = volts X current --- translation :
watts = volts X amps
1500 watts divided by 115 Volts AC = 13 Amps
Use a proper extension cord that can handle at least 15 amps. Also remember that your house outlets are rated at 15 amps.
Hope this helps you.
Old Dec 5, 2004 | 05:36 AM
jrs_big_ford_f150
Also, click here for more info. If you are worried about your electric bill you can can always get a heavy duty electrical timer and set it to turn the block heater on 3-4 hours before you leave in the morning (or whenever you leave for work, etc.)
jvmcc
Jul 22, 2016 02:04 AM
jvmcc
Electrical Systems/Wiring
Jul 21, 2016 05:48 PM
EXTREMEFUN1300
Dec 13, 2010 10:56 PM
wmiller
35
Nov 23, 2008 06:51 PM
reamer
Nov 1, 2005 09:55 PM
