'02 Ranger transfer case service
Old Dec 5, 2004 | 01:08 AM
Metro2's Avatar
Metro2
Anybody know how to drain the transfer case on the 2002 Rangers? The fill port is in the back side of the unit, but I can't find anything that looks like a drain plug..The 5 speed manual is quite obvious where the drain and fill plugs are..Do you have to remove a component from the case to drain it? Or do you have to siphon the fluid out? Thanks in advance!
Metro2
Old Dec 5, 2004 | 08:43 AM
01RangerSC's Avatar
01RangerSC
The drain plug is on the lower left hand side of the transfer case. It should look identical to the fill plug and is behind the damper weight.
