460 problems
Old Dec 4, 2004 | 10:04 PM
ford250-460's Avatar
ford250-460
460 problems
I need some guidance. My truck was leaking exhaust from the back of the engine and generally running awful. (rough idle, 5mpg, black smoke) my mechanic had me replace the EGR Tubes off the back of the engine, he replace the O2 sensor, tuned it up and it ran great for about 1500 miles. (smooth idel, 10-12 mgg, lots of power, no smoke and no smell of exhaust) I had taken it to a muffler shop after we did the work and they assured me the original exhaust was intact and they welded one small leak, all else was good.
now after about 1500 miles the symptons of exhaust smell, bad idle and awful gas milege (90 miles for about 20 gallons)
Now my mechanic tells me that this year modle has computer issues and that most likely the comp. is telling the truck to run like crud. He suggested either replacing the computer than retuning, or putting a piggy back computer on the old computer to straigten out the codes then retunning.
Has anyone heard of this, dose it sound reasonable and are there any suggested courses of action I might take to help do the correct thing?
Any help is appreciated. Thanks
Old Dec 4, 2004 | 11:39 PM
LxMan1's Avatar
LxMan1
I've never heard of this. Is it giving any codes? I would first check the vacuum line to the map sensor. This is what tells the engine how rich to run. With no vacuum, it will run full rich.
What year is it?
Old Dec 5, 2004 | 01:53 AM
ford250-460
Smile
It'a a 1994. I don't, personally, have the ability to pull codes off the truck. I have not had the codes pulled since it began running rough and sucking gas again. I am reading my Haynes repair manual and am liking the idea of checking the fuel pressure regulator. I will take your advice and look into the MAP as well.
any thoughts on the concept of the computer being goofy. The Mechanic stated getting a new one, or a piggy back that would translate code into the new code that is being used, and would have an in-cabin control system. something about me controling different things (I am assuming fuel pressure, air pressure, etc) from inside the truck.
any advice is helpful, thanks for the response
Old Dec 5, 2004 | 01:56 AM
ford250-460
it should be noted that I have all this bizarre info from my mechanic because he hasn't seen the truck yet. This is all from a phone conversation and he made these speculations based on a recent situation in which a similar 460 needed a new computer. He was able to track down, through Ford, that there had been some recalls on some trucks with this computer system and that this was the solution for another customer. I plan on having him plug it in very soon
Old Dec 5, 2004 | 05:10 AM
Icicle's Avatar
Icicle
pluggin in a computerized truck is the very first thing you should do, always.
Without that your stabbing at a mouse in the dark with a pitchfork, only the pitchfork is your wallet. take advantage of that computer, if you dont get any codes, then start stabbing away, my .02
good luck...BTW what year is it?
Old Dec 5, 2004 | 12:39 PM
LxMan1's Avatar
LxMan1
AutoZone and other parts houses will get the codes for free if you take the truck up there.
Old Dec 5, 2004 | 04:17 PM
ford250-460
thanks for the advice guys, I appreciate the heads up. Unfortunatley, the "check engine" light is not on, so the Auto Zone cant tell me squat. O'rielly has a piece of equipment that may do a better job. They say you can rent it and return if for no cost. sounds bizarre. I'll see what I can do and put some more info out there.
Great site with tons of help. Happy to have found it. Thanks
Old Dec 5, 2004 | 05:42 PM
LxMan1's Avatar
LxMan1
Good luck
Old Dec 5, 2004 | 05:53 PM
ford250-460
I have some codes!
KOEO code 111 (my haynes bood states "failure description" as "System Pass"
any thoughtsF?
KOER codes: 172
332
18
No help from Hanes on these
Can anyone translate these codes into a direction to begin looking?
Thanks.
Old Dec 6, 2004 | 12:15 AM
LxMan1's Avatar
LxMan1
172= O2 sensor indicates lean Bank 1 (passenger side)
332= insufficient EGR flow detected
12 = no good code for a 1994 should be a 3 digit code.
Does it have a mass-airflow sensor on it? It could be dirty. If so, try spraying the small wires in it with carb cleaner.
Old Dec 6, 2004 | 10:04 AM
ford250-460
Thanks, I will retest and see what the last code was.
explain "lean bank" passanger side.
I will check to see about the air flow sensor.
Good stuff.
Old Dec 6, 2004 | 10:31 AM
LxMan1's Avatar
LxMan1
It means that the 02 sensor is showing that it is running too lean and the computer is compensating by richening up the mixture as much as it can. This would explain why it is running rich.
Need to figure out why it is showwing lean. Bad injector, bad 02 sensor,etc
