99 Ranger 3.0l
Old Apr 17, 2001 | 10:50 PM
dougkitts's Avatar
dougkitts
99 Ranger 3.0l
Check engine light just went on. what are possible causes?
my truck is well maintained.
Old Apr 18, 2001 | 06:35 AM
greenpus's Avatar
greenpus
99 Ranger 3.0l
check to make sure your gas tank cap is secure.
other then that you will have to get a code reader for the OBC II
Old Oct 22, 2001 | 02:51 PM
79_1ton's Avatar
79_1ton
99 Ranger 3.0l
Also check the air intake, if this hose is loose or there is a hole in the hose you will get this same problem. Truck will run a little bit rougher of an idle when this is the problem also.
Old Oct 22, 2001 | 06:36 PM
N_B_A's Avatar
N_B_A
99 Ranger 3.0l
