Sponsored by: Real Truck
Brake controller & running lights
Old Dec 4, 2004 | 03:01 PM
gobeal's Avatar
gobeal
Smile Brake controller & running lights
Hello everyone, I'm new to the site and a proud owner of an 2000 F250 4x4 V10.
I need some help with the trailer running lights. Truck has the factory tow package, relays, fuses etc. I have the ford brake controller wiring harness with 5 wires going to a 4 wire controller. The brown wire from the harness is for trailer running lights. Where do I pull power from for this conections? The trailer running lights don't work with only the 4 brake controller wires connected.
Thanks for your help.
George
Old Dec 4, 2004 | 03:23 PM
wlihntr's Avatar
wlihntr
the brown wire on the trailer controller harness is for illumination of the controller (if needed) your running lights have nothing to do with the controller hook up and neither do the 2-30 amp fuses or the relays that come with the trailer tow kit. you frist need to check fuse #'s 4, (20 amp mini) and 8 (15 amp mini) in the under hood fuse box. if thats not it then start tracing wires.
Old Dec 4, 2004 | 03:30 PM
gobeal's Avatar
gobeal
Cool
Thanks. This doesn't sound good. All fuses look OK. I'll pull them and double check with meter. I hate trailer electrical problems.
Thanks again.
Old Dec 4, 2004 | 03:42 PM
wlihntr's Avatar
wlihntr
if you need a wireing diagram i can email one to you...just let me know
Old Dec 4, 2004 | 04:35 PM
gobeal's Avatar
gobeal
Smile
Problems solved. Bad fuse. Looked good but meter said otherwise.
Thanks again
