79 Ranchero brake problem
Old 10-28-2004, 09:31 PM
79rancher_boy's Avatar
79rancher_boy
79rancher_boy is offline
I have just changed my rotors and pads on my 79 ranchero. When i put the pads on however, the caliper barley fits on the rotor making a very nasty sound when driven. I have tried to open up the caliper all the way and it is still very tight. How can i make it so the pads are not putting so much pressure on my rotor? My pedal is also messed up. When pushed it goes all the way to the floor then starts to stop. the pedal does not come up right away and it is very loose. I bleeded my brake fluid and it is still not working properly. What is wrong?
Old 10-30-2004, 04:45 PM
Rancheroracer's Avatar
Rancheroracer
Rancheroracer is offline
Sounds like you may need calipers repaired, pistons may be sticking. Then bleed after repair.
Old 12-15-2004, 10:52 PM
Sanddoc's Avatar
Sanddoc
Sanddoc is offline
Brakes
Not an unusualy problem as cars get older..
the piston has probably developed a small ridge on the
cups and needs to be cleaned... they do make a spreader or
you could make one yourself, and push the piston all the way in,
then clean around the cup as much a possible, or you could
take the piston out and clean it... But really rebuilt
brake caliper is not very expesive $15-20 I would think...
do both sides..
Best
bismic
03-23-2012 03:27 AM
coleyslawn
12-01-2008 09:16 PM
CPB
05-04-2004 05:08 AM
Quick Reply: 79 Ranchero brake problem
