Checking for pinholes?
Old Dec 4, 2004 | 12:07 PM
RawPower's Avatar
RawPower
Whats a good way, or do you just get a flash light and feel for them?
Do you need to clean teh cylinders, or not?
Heads are off by the way...
Old Dec 4, 2004 | 09:31 PM
PLC7.3's Avatar
PLC7.3
Check out this info......... Posted by a friend ....Eric actually put his heads back on I believe to be able to pressurize the cooling system.
http://www.samantha.cc/Engine5.html
have a gander...
if you notice, the water just appears to be coming from no where... cavitation holes are very very small and usually don't leak until there is at least the weight of water in the heads pushing down on the water in the block and force the water out. And when it gets hot and the cooling system heats up it pushes water out the holes. So basically you can't see the holes at all. If you get some paint thinner, pour that in the block, it's thinner and will seep through the hole easier than coolant or water.
Mine cavitated on cylinder number 4, i hear 7 and 8 are common though.
Old Dec 5, 2004 | 03:25 PM
RawPower's Avatar
RawPower
OK, thanks. Im not sure that I want to put the heads back on just to test it when I could do the paint thinner way. Not to mention refilling the block and radiator. So Ill do that.
Old Dec 5, 2004 | 11:08 PM
PLC7.3's Avatar
PLC7.3
I think IH has a kit they use, it has block off plates and rubber gaskets in place of heads and lower coolant manifold plug and upper one too I believe so they can pressurize the block. No need for rad then.
