air pump constantly running
Old Dec 4, 2004 | 11:58 AM
tberryccf's Avatar
tberryccf
Help..
On my wifes '00 expedition eddie bauer, there is a air pump mounted on the left front fender under the air clearer that just started running all the time, even when the key is off, and at the same time the ABS light came on on the dash..
There is no error code in the OBDII, or not one I can read...
I unhooked the power to the pump to keep it from burning up...does anyone know what I need to do next??
Old Dec 12, 2004 | 03:07 AM
jester34's Avatar
jester34
listen around your front tires to see if you hear air leaking. The air line going into your struts could be loose. Or your height sensors could be off there clips and pressed together. If your pump is constantly running then your truck should be sitting very high in the air if this is so then you dont have a leak but if your truck is not raises, check the sensors: Front is behind the driver side wheel, and the rear is under the truck on the cross member by the rear axle.
Old Dec 20, 2004 | 09:57 PM
ST8FB's Avatar
ST8FB
I just began experiencing this problem tonight and was wondering if you found out what the problem was. It appears to be the ABS system from what I can tell, but don't know why it continues to run.
Old Dec 22, 2004 | 02:17 PM
ST8FB's Avatar
ST8FB
I removed the 50A maxi-fuse for the ABS and got the pump to stop running, but would still love to find out what is causing this if anyone has any idea.
Thanks.
Old Dec 26, 2004 | 09:20 PM
MIKE1646's Avatar
MIKE1646
My pump just get lauder and lauder with time.
Old Dec 26, 2004 | 10:54 PM
Big Craig's Avatar
Big Craig
lauder? maybe louder??
Old Dec 27, 2004 | 09:20 PM
MIKE1646's Avatar
MIKE1646
yeah that's it "louder"
Old Dec 28, 2004 | 10:30 AM
FX4_FAN's Avatar
FX4_FAN
Go to Ford and get the new double isolator brackets
Old Dec 28, 2004 | 11:55 AM
Iceman8984's Avatar
Iceman8984
Do you have just the load leveling in the back or all the way around? My Navi had a simular problem and I found the quick connect for the air line was split. It was not possible to hear the leak running the compressor motor so I disconnected both lines from the air pump and put compressed air to them and was able to hear the air escaping. Mine was actually the left front line right in front of the under hood fuse box. Good luck
Old Dec 29, 2004 | 12:57 PM
ST8FB's Avatar
ST8FB
It sounds like the original poster is having the same issue I am and if that's the case, it is the ABS motor/pump that is running, not the suspension or load leveling. I am still interested to see if anyone else is having or had this problem and what was involved in fixing (ie cost, etc.)
Thanks.
Old Jan 22, 2005 | 10:42 AM
tberryccf's Avatar
tberryccf
Arrow
I think it is the ABS pump, I don't have the load leveling suppension on the '00.
I didn't try the fuse as ST8FB suggested, (I just unplugged the pump). I'll go plug it back in and try the fuse and see if that cuts it off as well.
I found a company in Idaho that can rebuild the ABS box for about $200, but I don't want to rebuild something that isn't the problem.
My Ford dealer wanted to replace three components (pump, module, and something else), to the tune of $1800, so the dealer doesn't seem to know the problem either (as a matter of fact, they didn't even read my note and plug the pump back in). I don't have an xtended warranty.
t
Old Jan 22, 2005 | 11:22 AM
tberryccf's Avatar
tberryccf
OK,
I plugged the pump back in, and it came on instantly with the key off, and then pulled the 50 amp abs fuse, and it went back off. there is no fuse in the slot for air suppension..
I guess I will pull the module next month and send it off, unless someone has something else for me to try first.
Old Jan 22, 2005 | 07:25 PM
ST8FB's Avatar
ST8FB
I'd be interested in hearing about the possibility of rebuilding the ABS box if you go this route. I have been afraid to take it to the dealer for fear of the shock when they tell me the cost to repair.
Good luck and I'll let you know if I find out anything new.
Thanks.
Old Mar 22, 2005 | 02:33 PM
FCEYACHTS's Avatar
FCEYACHTS
Air pump/air suspension system
Is there a way to replace the air system? I have a 00' Expedition also and the pump runs quite a bit but not all the time
