hey guys this is my first ford truck i have a 2004 heritage single cab f-150
i just purchased a roll pan and there is no place for the spare tire lowering hole. if i had my body guy cut a hole it would look like crap. is there any way to relocate the winch sytem or make shift a device to lower it. please help me!!!!!
That's a good one. I'm sure it can be done (professionally). I would explore the drilling of the new hole to match the OEM hole. That's probably the easiest, and cheapest, way to go. Let us know, k. JP
Relax, you can do it! I think it would look trick.Put the roll pan in loose and before paint. Transfer punch the location with a center punch, drill small hole first to make sure. Drill full size and square file the key for the stock key set to fill the hole. Test, paint, and install roll pan and install key set.
Just a thought, and probably what I would do, but I am **** about stuff like that. Let us know what you do and send pics. Most important is to take your time and get it right the first time! Good luck!
