Well, hello yourself. Are you going to tell us about you or your truck?
And since I haven't done this for a day or so...................
Please read the forum guidelines and the READ FIRST notes in each forum. They'll get you off to a running start here. If you scan the entire list of forums, you'll find the ones that pertain to your needs. Thanks for joining us!
Also, you have 1 hour after posting to go back and add to or edit your post, then the little "edit" button disappears.
Well, all I can offer for your old computer is an aspirin and call me in the morning. I think I have that same problem.
As for your Ranger, there are several forums that can pertain to your issue. I'd scope each forum out, find the one that closest matches what's going on..or not... then post a more detailed description and I'm quite sure someone with good computer knowledge will happen along soon enough and offer some advice or a direction to follow. Good luck!
