Will a bad o2 sensor throw codes
Old Dec 3, 2004 | 07:22 AM
Jrock909's Avatar
Jrock909
I was wondering if a bad o2 sensor will throw codes to the computer therefore throwing a check engine light????
Old Dec 3, 2004 | 08:49 AM
bigbluebronco43's Avatar
bigbluebronco43
I think it should. I haven't had it happen on my truck but it did happen on my car (96 jetta). Usually the check engine light comes on only from emissions and sensors, so I would suspect it would. Check out this site- www.fordfuelinjection.com and try the self test-its a lot easier then it may seem. I did it and found 2 codes, and I didn't have a check engine light on.
EPNCSU2006's Avatar
EPNCSU2006
I think an O2 code will turn on the CEL. The O2 sensor could need replacing even though it doesn't set a code. I've heard replacement intervals of anywhere from 50-80000 miles, so if it's been that long, you might consider replacing it.
Old Dec 3, 2004 | 09:10 AM
fefarms's Avatar
fefarms
O2 sensors and codes in general are handled very, very differently between post 1996 OBDII cars/trucks and pre-1996 OBDI cars/trucks.
The EPA mandated the concept of a "drive cycle" for OBD2. If the vehicle completes an entire drive cycle with any of the O2 sensors out of "expected" range during a reasonable portion of same, it will light the check engine light. The light will stay lit, even if the condition goes away, until the code is cleared from the computer with a scanner or by disconnecting the battery. The EPA also mandated some standardization in what codes go with what condition and the form factor of the self test connector.
OBDI vehicles typically light the check engine light only WHILE a problem is being experienced. As you speed up and slow down, the problem may go away and the check engine light will go out whenever it does. There was no standardization at all across manufacturers, so the codes and behaviors can vary quite a lot from one make to another.
Both OBDI and OBDII may set continuous memory codes like mad without you ever noticing the check engine light.
Old Dec 3, 2004 | 08:10 PM
natron343's Avatar
natron343
Talking o2 sensor
on my 91 f150 5.0 i noticed over a few days time that my mpg was dropping, eventually down to 6 mpg!!! normally 16-18. i also noticed at the same time my speedometer was running about 5-10 mph faster!!! the truck still ran and idled perfect. WEIRD. no check engine light! i put a code reader on it and it came up as a o2 sensor. i installed a new o2 sensor and both problems went away!? i dont know if that will help you or not. has anyone ever heard of this situation?
6.9idiatsturbo
Modular V10 (6.8l)
Mar 5, 2017 09:59 AM
96halfton
Nov 6, 2016 04:31 PM
Duckman77
May 13, 2013 08:37 PM
Big Bald
2004 - 2008 F150
Jun 24, 2011 07:35 PM
eigenvector
1983 - 2012 Ranger & B-Series
Nov 15, 2009 11:24 AM
