I think someone is confused!
check this site out and tell me if some of those mods for the superduty are anything close to being true.
http://groups.msn.com/BHMS/swampdonkey2.msnw
-cutts-
-cutts-
Assuming the guy really does have that gearing he's got it all backwards anyway. I was always under the assumption that if you have different gearing front n rear, that you'd want a teeny, tiny bit HIGHER gearing in front...so that when in 4 wheel drive, the front will pull the back end....his gearing would actually cause him to get stuck easier...if it worked very long at all. I think mud racers...the real light & fast ones... have higher gearing in front so that the front spins much faster and floats the frontend easier. I may be wrong there though.
Well I don't know what he has for axles but they aint rockies he doesn't have enough lift for them, and I agree my big truck has a alot bigger engine than the 7.3 and only runs 5in exhaust. and as far as the split in gear ratios I do it but if he is right his is backwards should be lower geared in the rear. So have to agreee with the high on crack comments
edit fordlover you type too fast.
the only reason to have different gears in the front is to run smaller / larger tires than on the back, or because some guy in a show truck is a tool.
i've been looking and i don't see the ladder bars thats under it (supposedly) and also i don't see a hydro assist cyclinder?!?! maybe all the steering stabilizers are in the way! and how the hell is that an aftermarket front bumper? it looks like what came with it from the factory!
-cutts-
-cutts-
Originally Posted by bremen242
It doesn't matter. They have to be as close as possible... ie 3.50 3.54, 4.09, 4.11 etc etc.
