Died tonight, any ideas?
Old Dec 2, 2004 | 10:48 PM
2112's Avatar
2112
On the way home from work which is a 20 minute surface street drive, My 2004 6.0 started chugging up a hill an billowing white smoke out the pipe. It was dark, I think it was white.
The truck never died completely but could not run under its own power. The exhaust had an unusual foul smell.
I let it sit for 20 minutes and with my wife following me I limped into the dealer and left it in the lot. Ran better after sitting but still smoked and smelled terrible.
The truck has 12,500 miles on it. I ran an edge between miles 3,000 and 9,000 but took and left it off since the truck would occasionally act like it was out of fuel. It did this before the edge too. The dealer has always said everything is OK. Also had torqueshift solinoids replaced at 9,000 miles.
Any ideas?
Old Dec 2, 2004 | 10:50 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Any ideas?
Does the exhaust smell of coolant or oil?
Old Dec 2, 2004 | 10:54 PM
AntiGrav118's Avatar
AntiGrav118
Any ideas?
Well, honestly, i'm not one of the more knowledgeable posters on the forum but due to the polluted emanation thereof your truck (thesaraus.com) i'm guessing you may have a bad cat. I can't believe you'd have problems with it so soon, though...
It's under factory warranty i suppose. Definetely see what the dealer has to say.
Old Dec 2, 2004 | 10:57 PM
SpartanDieselTech
Former Vendor
IMO, I think you are looking at a blown head gasket or a loss of compression due to a hole in a piston/skirt/ring ect. from heat; that is why I asked about a coolant/oil smell.
This is the exact same behavior as mine when I ripped out a wristpin from timing..
Old Dec 2, 2004 | 11:01 PM
2112's Avatar
2112
I do not recognize the smell. If it is coolant is is very burned and very obnoxious.
I never ran it hard. The edge was only on the lowest level and not on at all when I towed with it.
My gut instict is it is bad. I have luched big gasoline boat engines before but there is always a big bang and clanking etc. This came on at 40mph and 1700 (or so) RPM.
Old Dec 2, 2004 | 11:17 PM
shocktower's Avatar
shocktower
Waste Gate
On my '95 it blew the waste gate and it did the same thing ,ran but no power and white smoke
Old Dec 3, 2004 | 07:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
When they loose boost they really are slow
Old Dec 3, 2004 | 07:43 AM
2112's Avatar
2112
but this time it could hardly move. After 20 minutes it had enough power to limp 5 miles to a dealer. Still sound like it is in the turbo?
Old Dec 3, 2004 | 10:17 AM
huntercgr's Avatar
huntercgr
What year was your engine built? On your way to the dealer, did it shake violently at times? Dead pedal and then all of a sudden you had power? If so, could also be bad injector(s).
Old Dec 3, 2004 | 10:30 PM
2112's Avatar
2112
Build date is 11/04
Picked it up tonight. They said the EGR valve was plugged. I did drive it home tonight and it ran OK. They also Flashed the PCM and TCM. That is giving me a huge lag time after hitting the gas pedal and getting a response and the shifts between 2nd and 3rd are very hard. It was too dark to check smoke although there was some on harder accelaration that I could see in the dark.
My Questions for the Diesel experts;
Does a plugged EGR sound logical for my symptoms? They said it was the source of all the smoke although they saw no smoke today?
Could more serious damage occured due to this plugged EGR? What caused all the foul smelling smoke?
If I am in the middle of nowhere and it happens again, should I just unplug the unit? (I know many of you already have done this).
Should I also have the exhaust back pressure sensor replaced?
Last but not least....Did the Edge fuel box create this problem?
Thanks Guys
Old Dec 4, 2004 | 08:10 PM
2112's Avatar
2112
Expert opinions out there???
Old Dec 5, 2004 | 04:47 PM
pappy42's Avatar
pappy42
I'm told, that in science, X is an unknown quantity and a "spurt" is a drip under pressure. Keeping in mind that I'm no "expert"; I keep my EGR valve unplugged all of the time except when I take the truck to the dealer for service.
I really don't have clue about what would happen if you unplugged the EGR after it was plugged up.
Old Dec 5, 2004 | 07:42 PM
2112's Avatar
2112
I have not located it as of yet, do you have a quick description as to where it is?
Do you have the batteries disconnected when you plug and unplug it?
Old Dec 6, 2004 | 05:38 AM
kwiknova's Avatar
kwiknova
Check the tech folder. It has helped me a lot.
Old Dec 6, 2004 | 10:29 AM
2112's Avatar
2112
I assume you mean here on the site, All I can find is changing out turbos and cam sensors. Could yo be more specific? Thanks.
